netblokeusa's avatar
netblokeusa
WiFi dropping sporadically
I have gone through these forums looking for a solution....
So I use Xfinity.
My Cable modem is an Arris SB8200.
It seems that my WiFi is a sporidically dropping (and has been for some undetermined time frame, it may be when I upgraded the Cable Modem a few months ago)
Netgear support wants to charge me for the fix. they say it is some setting I have incorrect. I can't really afford to drop $90 for a new support contract.
Any ideas on what I need to alter?
Thanks!
  • plemans's avatar
    1. what actual router do you have?
    2. what firmware is on the router?
    3. is it only wifi? do wired devices drop?
    4. are you using wan port aggregation with the sb8200?
