X75
Nov 22, 2025Follower
Wifi is not connecting to with Blink Sync Module
Did you ever get this sorted? I have been searching for answers to this problem and keep getting told to follow this step or that step to reboot and resend but nothing works
CrimpOn
Nov 22, 2025Guru - Experienced User
Probably should point out that when connecting a new device to the network for the first time, I always place it in the same room as the RBR50 router. Once the device has connected successfully and appears to be working, it can then be relocated to a more desirable location. (in the case of the Blink sync module, it remains in the same room as the router and appears to have adequate coverage from that location. No point it putting it anywhere else.)
