X75
Nov 22, 2025Follower
Wifi is not connecting to with Blink Sync Module
Did you ever get this sorted? I have been searching for answers to this problem and keep getting told to follow this step or that step to reboot and resend but nothing works
alexdavid
Nov 23, 2025Aspirant
I’ve run into this before, and it’s really frustrating. A lot of the usual “reset and retry” steps don’t help when the Sync Module just refuses to connect. What finally worked for me was:
Making sure the 2.4GHz Wi-Fi band was enabled (Blink won’t connect to 5GHz).
Changing the Wi-Fi channel to something less crowded (like 1, 6, or 11).
Power-cycling the router and the Sync Module after making those changes.
If none of that works, sometimes deleting the Sync Module from the Blink app and re-adding it as a fresh setup does the trick.
Not sure if your issue is the same, but hopefully this helps a bit!
