Mvmp103's avatar
Mvmp103
Follower
Jan 11, 2021
WIFI keeps breaking up RBR50
Since 3 days our Orbi keeps disconnecting and restarting the Wifi. It mentions "internet not secured" disconnects the Wifi and restarts the Wifi.
The normal internet connection via LAN (cable) keeps working fine.
I have rebooted several times. And the problem is getting worse.
The Orbi has been relatively stable (but not as good as I hoped) . Now the Orbi is basically not usable as a Wifi system.
Any ideas about a solution?
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
    Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
  • CrimpOn's avatar
    CrimpOn
    Could you please comment on how many devices exhibit this behavior, and what kind of device they are?
