AshrafulHasan
May 09, 2020Aspirant
WiFi range is very poor on my Orbi RBR20
Hi. I have a RBR20 router and no satellites. The WiFi signal of the router is poor. I have downloaded and ran the WiFi through the Netgear WiFi Analytics app. The result is attached. What's surpr...
May 11, 2020Guru - Experienced User
Building materials like brick will impact wifi signal on any wifi router. What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
- AshrafulHasanMay 11, 2020Aspirant
Hi.
The Orbi firmware version is 2.3.5.36.
The manufacturer of the ONT device seems to be an obscure local company but the model number written is FD600-504G-HR220.
I do not have any satelites - just the RBR20. I appreciate that bricks can cause disruptions but that doesn't explain the poor signal from 10 inches away from the router?
- FURRYe38May 11, 2020Guru - Experienced User
What wireless devices are you using?
What speeds UP and down do you with wired connections?
Try updating the RBRs FW and see:
First manually download the RBS and RBR FW files from here.
Unpack the FW from the .zip files.
Use a wired PC for this process. Safari(Mac), IE11(Windows), Firefox or Opera browsers are recommended.
Log into the RBRs web page and send the FW file there first.
Factory reset the RBR and setup from scratch. After makeing sure the system works after setting up, be sure to make a backup configuration to file for safe keeping. This saves time if a reset is needed again.
- AshrafulHasanMay 15, 2020Aspirant
Hi.
What wireless devices:
- 4 iPhones
- 1 iPad
- 2 Android Phones
- 1 wired Surface Pro 3
- 1 Apple TV
- 1 Alexa
- 2 Smart TVs from Sony & LG
On the wired connection I am getting the following:
Ping - 2ms
Download - 48.11 Mbps
Upload - 23 Mbps
I have updated the FW of the RBR20 - With that the WiFi performance has not changed at all.
