mkfein
Aug 02, 2019Star
WiFi Slow after 2-3 days until reboot?
I'm really at my wits end fighting with this Orbi System. I've read all the relevant forum posts I could find and am still struggling. I have 200 Mb/s service from Xfinity. Orbi RBR50 is connecte...
OUZY
Feb 29, 2020Aspirant
can't edit my previous post. Here is update. 1. the linux system look like different from SUSE Linux or similar. 2. "nvram commit" was not save to storage before reboot. Don't figure why yet. 3. After reboot, the crontab job NOT existing anymore. ... Therefore, please ignore my previous post till has correct commit solution .
Mar 01, 2020Guru - Experienced User
:smileyfrustrated:
Thanks for letting us know. I would recommend fully testing your solutions out before posting. Ensure testing and end results meet your expectations. IF the solution fully works, please post here:
- Geddy007Apr 04, 2020AspirantI had the same problem, but it's now fixed. Wired speed from router to ISP over 200 Mnps, same on wifi for router and satellites. After 2-3 days, wifi when connected to router dropped to 40, but both wifi through satellites and wired from router to ISP remained over 200. So, it was solely a problem with connecting by wifi to router itself.
My problem was LG smart TV. I erased wifi internet connection from TV setup. After resetting router, the wifi speeds haven't dropped in over 3 weeks. Before, it routinely dropped every 2-3 days.
Go through everything connected to the router itself, disable one at a time, reset and wait to see what fixes it.
My setup:
Firmware 2.5.1.8
RBR50, RBS50 x2 - no daisy chain
Armor Bitdefender active- ekhalilApr 04, 2020Master
.......Good observation Geddy007. I think I've seen similar behaviour in my Orbi previously. What is special with this TV? Does it also have a wired connection to the network? Was it attached with Orbi previously as wired? Does the TV also act as an AP? Please look where this TV can cause loops in the network by having two different interfaces.
- Geddy007Apr 04, 2020AspirantTV was never wired - always wifi. It's not an AP that I know of. I never really even used the wifi connection, since all my entertainment comes through FireTV stick. The TV wifi connection was only used for the TV to get software updates for itself, which I don't really need. Now, if I want to check for a TV software update, I can manually connect to check and then erase wifi settings again.
- FURRYe38Apr 04, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
.Try disabling the following and see:
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).Above suggestions working:
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
My setup:
Firmware 2.5.1.8
Armor Bitdefender active- Retired_MemberApr 04, 2020
FURRYe38 wrote:What is the size of your home? Sq Ft?
My setup:
Firmware 2.5.1.8
Armor Bitdefender activedidn't you already post this mess in message 11 here..................??????
- fmalloyNov 28, 2020Luminary
Geddy007 Identical problem here (RBR20+2 RBS20). Full speed for 4-7 days, then drops to 40~45Mbps, but only to WiFi devices connected to the router, not the satellites (strange). I tried disconnecting every device to no avail, but I forgot two - the Samsung smart TV, and a little Netgear dongle that connects to the dish satellite box to download the guide info. I will definitely try those next...
I think you are the only one who actually solved this problem!
- Geddy007Nov 28, 2020AspirantFingers crossed - let me know how it goes. I haven't had the problem since I blocked the TV.
