mkfein
Aug 02, 2019Star
WiFi Slow after 2-3 days until reboot?
I'm really at my wits end fighting with this Orbi System. I've read all the relevant forum posts I could find and am still struggling. I have 200 Mb/s service from Xfinity. Orbi RBR50 is connecte...
Geddy007
Apr 04, 2020Aspirant
I had the same problem, but it's now fixed. Wired speed from router to ISP over 200 Mnps, same on wifi for router and satellites. After 2-3 days, wifi when connected to router dropped to 40, but both wifi through satellites and wired from router to ISP remained over 200. So, it was solely a problem with connecting by wifi to router itself.
My problem was LG smart TV. I erased wifi internet connection from TV setup. After resetting router, the wifi speeds haven't dropped in over 3 weeks. Before, it routinely dropped every 2-3 days.
Go through everything connected to the router itself, disable one at a time, reset and wait to see what fixes it.
My setup:
Firmware 2.5.1.8
RBR50, RBS50 x2 - no daisy chain
Armor Bitdefender active
My setup:
Firmware 2.5.1.8
Apr 04, 2020Guru - Experienced User
Above suggestions working:
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
My setup:
Firmware 2.5.1.8
- Retired_MemberApr 05, 2020
FURRYe38 wrote:What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
.Try disabling the following and see:
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).Above suggestions working:
My setup:
Firmware 2.5.1.8
Armor Bitdefender activedidn't you already post this mess in message 11 here..................??????
- southbay82Apr 24, 2020Aspirant
EQUIPMENT: RBR40 with a Satellite (latest firmware (V2.3.5.32) as of april 2020).
I and was experiencing the same behaivor everyone on this thread has been messaging.
To recap..
The issue with download speeds limited to 40Mbps, would present itself about 3-4 days after reboot.
Restarting the router would temporarily resolve the problem.
Factory reset did not fix the problem.
Tuning down the 5ghz to 75% and 2.4ghz to 25% didn't help.
Mixed 20/40 mhz being disabled, did not help.
Eventually, I unplugged my satellite, and the issues did not persist. I am noW 11 days in, no problems,
I noticed my Surface book laptop which was 4 ft from the router (through a wall), would connect to the Satellite (50ft away, via many walls).
So i think either with an update, the mesh was no longer coordinating with my devices to have them associate to one AP or the other.
- yototogbloMay 09, 2020Tutor
So I'm convinced this issue is a firmware problem. In the past 2.5 months, I've bought 1 RBK53 (2 satellites), 3 different RBK50 and 1 RBK50V systems and on every one of them, I've had this problem. I have 1Gig internet w/ FiOS. My backhaul is wireless. I have about 50 total devices connected to both the router and satellite. Over WiFi, I typically get about 400/400 on the router and about 350/350 on the satellite. After 2 days, on every one of the systems, devices connected to the satellite consistently drop to about 35/40. It's very consistent and has occurred on all 5 systems I've bought. Therefore, I doubt it's a hardware issue. It's shocking to me that not everyone is complaining about this.
On the RBK53, the slowdown interestingly only occurred on 1 of the satellites. The 2nd satellite stayed fast. I then switched the location of both satellites and the one that originally had the slowdown still had the slowdown in the new location. The 2nd one stayed fast. As such, I doubt this issue has to do with devices connecting to satellites but rather, I think it's a firmware that affects almost all satellites but not every satellite. Maybe I've just been unlucky with 5/6 faulty satellites.
