Bugs3775
Dec 05, 2019Aspirant
WiFi speed slower then other routers
I’m on my note 10+. Right on the other side of my bedroom wall. Less then 10 feet from Orbi. 650 mb WiFi sped only. All other routers my note 10+ is at 866mb.
What’s wrong? Is the Orbi that bad?
Web pages seem to load slower then on any other router too.
I returned the router so I don’t have it anymore.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
