Amarjit
Nov 17, 2018Follower
Wifi Speed test
Recently purchased and configured it. Netgear Orbi app is showing the upload speed 27 MBps and downlaod speed around 500 Mbps.
I connected teh PC to Orbi network and checked the speed using Spectru...
Nov 17, 2018Guru - Experienced User
What FW is currently loaded?
Wired speed testing is preferred...
Have you enabled QoS on the Orbi router any?
I connected teh PC to Orbi network and checked the speed using Spectrun Speed Test and it is showing me .8 Mbps downlaod speed and 1.4mbps upload speed.
Any idea about this issue? Is it normal or did i make some mistake while configuring Orbi?
