FirstCup
Jun 25, 2021Guide
WIFI to barn 200' away?
Thanks everyone for looking! I set up this Orbi RBR50 with one satellite in my home last week, very good coverage around the house. I have a metal barn about 200' away where I would like to control a...
- Jun 27, 2021
Thank you, you have clearly shown me the light! Digging will not be an easy path but I had considered it a year or so ago, hense the 250' of cable in my closet. Thanks for the info on the outdoor satellite with no ethernet connection.
CrimpOn
Jun 27, 2021Guru - Experienced User
250' of ethernet cable is the least costly and best solution. Any WiFi access point (of any brand) can be mounted in the barn.
An inexpensive WiFi bridge, with any WiFi access point is the next least costly.
An Orbi outdoor satellite (RBS50Y) is the most costly solution (if it works).
The central issue is WiFi signals penetrating the metal barn wall. An outdoor RBS50Y may sync with the house system, but will it penetrate the barn wall? Running ethernet from the house inside the barn addresses this issue directly.
A WiFi bridge with one unit 'outside' at the barn with the ethernet cable penetrating the barn wall addresses the issue directly.
Orbi RBS50Y has no ethernet port.
FirstCup
Jun 27, 2021Guide
