donpearson
Mar 30, 2019Aspirant
WiFi traffic data
Is their a way for me to setup the traffic data to register the wireless data instead of internet... I use my Orbi in AP mode so it would be a much better use if it then no information at all as it i...
donpearson
I know most of the stuff is disabled in AP mode.
I’m not looking for a way to use a third party device, I’m hoping there’s a way for Netgear to sort it out or a hack somehow
Mar 30, 2019Guru - Experienced User
When i AP mode those features are disabled since they require the use of the router mode and WAN Port. When in router mode TM would be enabled. NG doesn't support TM being used in AP mode. IT's not technically feasable.
- donpearsonMar 30, 2019AspirantOf course it’s technically possible to show WiFi traffic data instead of internet traffic data.
- FURRYe38Mar 30, 2019Guru - Experienced User
Something to ask about here:
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
Good Luck.
- ekhalilMar 30, 2019Master
donpearson wrote:
Of course it’s technically possible to show WiFi traffic data instead of internet traffic data.When in AP mode, I think -but not sure- that you will still be able to see the statistics in the web GUI under >> ADVANCED >> ADVANCED Home >> SHOW STATISTICS, which looks like this:
- donpearsonMar 30, 2019AspirantSorry im talking about the app and not the web gui.
