aallred's avatar
aallred
WIFI Turning on and off several times a day
I have had my Orbi for several years and it has worked great.  However, the last month or so, it won't stay connected.  It probably disconnects at least 20 times a day.  I am constantly reconnecting to wifi during the day.  I have checked with my internet provider and I have a great signal, I have unplugged the power for 30 sec and then plugged it back in.  Any suggestions?
  • michaelkenward's avatar
    michaelkenward
    What happens when the wifi goes down?
    What firmware version do you have on the device?
    A number is more useful than "the latest". (It may not be by the time people read this.)
    • aallred's avatar
      aallred
      When the Wifi goes down, we just lose service to all devices.  I am using firmware V2.3.5.30.
      • FURRYe38's avatar
        Can you give some feed back to some of the questions presented?
  • FURRYe38's avatar
    Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
