StuMcBill
Jan 04, 2019Tutor
Will this work with a 2nd Satellite?
Hi,
I've just set up Orbi in my home, and would like to try and get wifi coverage in the garage also. Where I have positioned my first satellite, doesn't quite reach the garage. If I were to ...
Jan 04, 2019Guru - Experienced User
Whats the distance between the 1st satellite and the proposed satellite?
- StuMcBillJan 04, 2019TutorNot sure really. I'll check.
Probably around 40-50ft- FURRYe38Jan 04, 2019Guru - Experienced User
Give it a try. It should connect. If you have Daisy Chain enabled. On v210 FW though, seems that Daisy Chain maybe working incorrectly in the UI. So uncheck mark the box. This seems to enable Daisy Chain. Try putting a check box if it doesn't seem to work for you. I presume the connected satellite should show up on the 1st satellites connected devices list.
- StuMcBillJan 05, 2019TutorI don't have a second satellite at the moment, and don't really want to buy one if it's not going to work?
I could use a powerline adapter to get internet into the garage?
