StuMcBill
Jan 04, 2019Tutor
Will this work with a 2nd Satellite?
Hi,
I've just set up Orbi in my home, and would like to try and get wifi coverage in the garage also. Where I have positioned my first satellite, doesn't quite reach the garage. If I were to ...
Jan 04, 2019Guru - Experienced User
Whats the distance between the 1st satellite and the proposed satellite?
StuMcBill
Jan 04, 2019Tutor
Not sure really. I'll check.
Probably around 40-50ft
- FURRYe38Jan 04, 2019Guru - Experienced User
Give it a try. It should connect. If you have Daisy Chain enabled. On v210 FW though, seems that Daisy Chain maybe working incorrectly in the UI. So uncheck mark the box. This seems to enable Daisy Chain. Try putting a check box if it doesn't seem to work for you. I presume the connected satellite should show up on the 1st satellites connected devices list.
- StuMcBillJan 05, 2019TutorI don't have a second satellite at the moment, and don't really want to buy one if it's not going to work?
I could use a powerline adapter to get internet into the garage?- CrimpOnJan 05, 2019Guru - Experienced User
Yes, Powerline can be used to connect ethernet devices. They don't even know it's there. HOWEVER, Powerline technology comes with its own set of issues. It is distance sensitive. The farther you go, the slower the speed. It is sensitive to electrical panels and circuits. When you read the fine print, Powerline "works best" when adapters are on the same electrical circuit. In a modern home, this is unrealistic. It is also sensitive to the type of circuit breakers used. Any kind of power strip renders Powerline unusable (confirmed by experience).
I have gigabit Powerline adapters connecting a Tivo remote and a router (in the garage!). Tremendous speed to the Tivo because it not very far and on the same circuit. WAY less speed to the garage which is three times the distance and on a different circuit. It's enough speed for my needs, but the difference is dramatic.
Obviously, the two Orbi satellites will have to "see" each other for backhaul to work. There are numerous inexpensive "WiFi monitor" programs for Android and Apple handhelds. (I use WiFi Analyzer from the Android Play Store and just ignore the ads.) When you go to the garage where the satellite would be mouned, what 5G signal level does your phone (or tablet) report?
