Jefffe
Jan 27, 2026Aspirant
Win10 stopped connecting to my routers DNS server
I have had all my Win10 devices, both LAN and wireless, stop receiving a valid IP from my RBR50 Orbi routers today, and now they have no internet. There was no Windows update, and I went through exh...
Phixxit
Feb 04, 2026Aspirant
i had this happen to windows 11 pro computer.
the way i resolved this was to assigne static IP addresses IP4, every thing started to work.
this is some thing that started right after windows 11 update
Pc is upgraded propley fron win 10 Pro
Feb 04, 2026Guru - Experienced User
So Win11 had been working then suddently exhibited this issue after an update? Might check into this update and see if it can be removed to see if it fixes this.
There has been some known issues with recent Win11 updates. Something to check into.
What is the brand and model# of the ethernet adapter and wireless adapters in these PCs?
