colinha667
Mar 16, 2020Aspirant
Wired and wireless keeps dropping
I keep getting intermittent network drops with WiFi and wired. I just checked the logs and got this: DoS Attack: ACK Scan] from source: 23.246.6.184, port 443, Sunday, March 15, 2020 21:32:04 [D...
Mar 16, 2020Guru - Experienced User
What is the model# of the ISP modem the NG router is connected too?
colinha667
Orbi 2.5.1.8
Rogers Internet , hitron modem-CODA 4582
(In bridged mode)
(In bridged mode)
- Retired_MemberMar 16, 2020
another case for Orbi 2.5.1.8.....bad FW
- colinha667Mar 16, 2020AspirantI’ve actually noticed this started occurring after the firmware upgrade!
colinha667 wrote:
I’ve actually noticed this started occurring after the firmware upgrade!revert back to the previous FW
- FURRYe38Mar 16, 2020Guru - Experienced User
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).Has a factory reset and setup from scratch been performed since last FW update?
Above suggestions working:
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
colinha667 wrote:
Orbi 2.5.1.8
(In bridged mode)- Retired_MemberMar 16, 2020
FURRYe38 wrote:What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
colinha667 wrote:
Orbi 2.5.1.8
(In bridged mode):smileysad:
- colinha667Mar 16, 2020AspirantThe distance is good between the router and sat
This is occurring with wired (RJ45) as well. I have noticed this started to occur after the latest firmware update.
I have not tried a factory wipe yet.
