Shimmyhill
Sep 30, 2018Aspirant
Wired back haul better?
I have a Orbi RBR40 setup that replaced a Nighthawk router a while back, the WiFi is much better across our bungalow but we have been getting dropouts and I think it’s the satellite dropping - should I wire them together or are there reasons for not doing this?
I will start with the simple question but can give more details about my current configuration if needed!?
What FW is currently loaded?
What is the Mfr and model# of the IP modem the Orbi is connected too?
What is the Mfr and model# of the ethernet switch if one is in the configuration.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Yes wired backhaul is good and works well;..
For wired back haul:
Set up IP address reservations for each satellite and devices on the router as you add them to the router. The satellites need to be set up via wireless first. Then connect 1 satellite at a time to the ethernet LAN cable. Wait 5 minutes and the top led on the satellite should turn on BLUE. Set up an IP address reservation for the 1st satellite. Continue to do the same thing for the 2nd satellite. Then follow up with your devices.- ShimmyhillAspirant
Sorry for the late reply, death in the family made this a low priority issue!
2.2.1.210
What is the Mfr and model# of the IP modem the Orbi is connected too?Virgin media superhub 2
What is the Mfr and model# of the ethernet switch if one is in the configuration.Netgear GS295-100UKS 5 Port switch.
What is the size of your home? Sq Ft?Not very big, 3 bed bungalow but no idea on square footage, will look for sales sheet!
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.I would say 25 - 30 foot
Auto and 36
Any Wifi Neighbors near by? If so, how many?Not able to check, have an app on laptop but nothing on iPad and the laptop isn’t working at the mo :(
I have since I posted this (today infact) hard wired the satellite to base Orbi as I have been getting the familiar drop out between the satellite and base orbi - seeing the orange and blue glow too often!
You might set the satellite to a bit more than 30 feet. Could be causing some problems, even wired back haul.
Please confirm the model # of the swtich being used. Doesn't seem to come up in searches.
How was the update applied? Auto update or manually installed?
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. Hoping NG support can have a look at this. So try this out as well.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001
