WAP
Jan 17, 2018Apprentice
Wired Backhaul Intermittent after Reboot
Equipment:
ISP Modem/Router
RBR50 (in access point mode) fixed IP address of 192.168.1.53
RBR50 internet connection via yellow WAN port connected to LAN port of ISP Modem/Router
RBS50 #1
RBS50 #2
Netgear 16 port switch
WIFI devices consist of Apple and Windows Only (no android/google devices)
Orbi Settings:
Firmware- V2.1.2.18
The following is checked:
Enable 20/40 MHz Coexistence
Enable WMM (Wi-Fi multimedia) settings
Enable Implicit BEAMFORMING - Boosts Wi-Fi speed, reliability, & range for all mobile devices
Enable MU-MIMO
Allow external IPv6 hosts ping internal IPv6 hosts (as per http://192.168.1.53/debug.htm)
Wired Backhaul Trial #1:
Sat 1 wireless…browser GUI says satellite connection type=5G
Sat 2 wired directly to LAN port on RBR50…browser GUI says satellite connection type=wired
Enable Daisy Chain=Off
When rebooting RBR50 from the GUI, it takes 2 mins but the two satellites show up in the GUI as described above. (MOST STABLE SET-UP...AT LEAST RIGHT NOW)
Wired Backhaul Trial #2:
Sat 2 wired to Netgear 16 port switch which is wired to ISP router/modem…browser GUI says satellite connection type=wired
When rebooting RBR50 from the GUI, both Sat 1 and Sat 2 show up in the Connected Devices section of the GUI not the Connected Satellites section and both of Sat 1 and Sat 2 show up as wired. (I’M NOT SURE IF THIS IS A GUI ISSUE BUT I WOULD HAVE EXPECTED Sat 1 to show up in the Satellite section...didn't spend time looking at speedtest connectivity)
As soon as I turned off Sat 2, the GUI refreshed and Sat 1 showed up in the Connected Satellite section with connection type=5G
Wired Backhaul Trial #3:
Sat 2 wireless…browser GUI says satellite connection type=5G
Enable Daisy Chain=On
As soon as I connect Sat 2 to the netgear switch via ethernet bot Sat 1 and Sat 2 show disconnected but after about a minute Sat 1 shows up as a 5G satellite and Sat 2 shows up as a Wired connection.
Finally when rebooting RBR50 from the GUI on the Sat 1 shows up in browser GUI as satellite connection type=5G. Sat 2 never shows up again in the satellite section, it does show up in the connected devices section.
I can occasionally get full speed 400 MBps (up and down) out of the satellite #2 but it is extremely intermittent (other times it is dead…can’t even see the SSID)
Wanting feedback to tell me what tweaks I can make to Trial #2 and #3 to get ethernet backhaul to work on Sat 2 after a reboot. I will use Trial #1 for now but Trial #2 and #3 allow for a more optimal placement of the RBR50.
1 Reply
- t_kLuminary
WAP - You clearly already know this, but I'll just be explicit. You can't use the wired backhaul system reliably. It's a poorly implemented feature and there's nothing you can do about it.
You've provided greate detail in your steps, and you've done everything as a rational person would. However, it's not going to work. It was a feature they rushed out without bothering to check if it would work properly. Basically, the theme of the Orbi's.
I have a RBK53 system and tried a wired setup. I had similiar expeirences. I gave up. Went with the a Unifi system. No problems since.
