EyalS
Jun 14, 2018Tutor
Wired backhaul of RBR50 & RBS50 directly to ISP's modem/router
I'm trying to figure out how to configure wired backhaul.
After initial configuration, in which both devices RBR50 & RBS50 (with the latest firmware V2.1.4.16) wherein close proximity and I was abl...
DarrenM
Jun 18, 2018Sr. NETGEAR Moderator
You need to have the ethernet from the satellite plugged directly into the main orbi router not the ISP modem. you have the modem connected correctly to the orbi router.
DarrenM
- EyalSJun 18, 2018TutorThanks for the help.
The problem is, that as soon as I connect the satellite directly to the Orbi router, I’m loosing the internet from all the devices connected to Orbi (wired and wireless).
Is the wired backhaul really operational? I must use the wired backhaul, but it feels like it’s not mature yet.
