EyalS
Jun 14, 2018Tutor
Wired backhaul of RBR50 & RBS50 directly to ISP's modem/router
I'm trying to figure out how to configure wired backhaul.
After initial configuration, in which both devices RBR50 & RBS50 (with the latest firmware V2.1.4.16) wherein close proximity and I was abl...
Aug 15, 2018Guru - Experienced User
What is the Mfr and model# of the ISP modem?
I would do this, set up the ISP modem and use it's DMZ for the IP address the Orbi router gets from the modem. Put the Orbi router in router mode. Walk thru the setup wizard. If the modem uses 192.168.1.1 then the Orbi should auto change it's same IP address to something different so it won't conflict. Look at the modems connected client list to see what IP address the Router got from the modem. Set up a IP address reservation on the modem for this IP address, then input this IP address into the DMZ. Apply changes to the modem. Reboot the modem and Orbi router. Leave the satellite disconnected for now. Check to see if you get internet thru the Orbi router in this configuration.
- EyalSAug 15, 2018Tutor
Thanks @FURRYe3 for the detailed answer, but why?
Can't I use the Orbi device in AP mode? is this feature not working?
Configuring Orbi, in router mode will create a different subnet which will add complications, as some devices on the net connect directly to the ISP modem/router.
