Jduggs's avatar
Jduggs
Tutor
May 10, 2021
Wired backhaul Orbi
Hi, i've just installed a new network point in my office. Router is downstairs and wired an ethernet cable from the router round the outside of the house into my office with a network point. I then plugged in my orbi satellite hoping it would connect wired but it still acts wirelessly. Do I need to have a network switch or will this not work?
  • FURRYe38's avatar
    Check the LAN cable for quality and opertation. Maybe bad cable or terminating plug.
    CAT6 LAN cable is recommended.
    You can use a switch however it's not needed.
    https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
    NG GS-105/108v4, D-Link DGS-105/108 and HP ProCurve 1400/1800 series switches work for Orbi systems.
    Run a test with the RBS near the RBR with a ethernet patch cable to see if the RBS maintains ethernet status. If so, then your problem is elsewhere in the cabling or RJ45 plugs and jacks.
    • Jduggs's avatar
      Jduggs
      Tutor
      I connected a cable directly from the router to the satellite and this worked. Cable from the access point in the wall connects to my laptop fine so I know the internet is working. Just strange that if I connect the satellite to the lan port it does not act as if it’s wired in. Any other suggestions?
      • FURRYe38's avatar
        Something with the cabling or jacks thats in wall would need to be looked at.
