Suli3's avatar
Suli3
Wired backhaul setup - device chain
Hi all,   Yesterday I got finally my Orbi system and installed it immediatly. Now I'm trying to establish an wired backaul and I'm not clear about the exact setup.   My Setup: My house has an...
  • Suli3's avatar
    Suli3
    Sep 14, 2018
    Hi
    Thanks for your reply.
    I do not understand what you mean with Mft but this my setup:
    Maybe I also explained it a bit wrong. It is not only a Cable modem it is also a router (inkl. Wlan).
    (Cable 500Mb/50Mb)
    UPC Connect Box CH7465LG-LC (Router ISP) --> TRN TEG-S16D (Swich unmanaged) --> Orbi System (RBR50 Orbi Router + 2 Satelites)
    The router of the ISP provider and the switch are in the cellar.
    QUESTIOn 1 again: Do i need to connect the RBR50 to the yellow internet port or to one of the other ports?
    According to https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
    Especially the third option i see (switch --> Orbi System (router + satelites) exactly how I did it or do I read this wrong?
    Your advice Cable Modem -> Orbi system (1 router) -> Switch -><- Satellites and All other Network devices connected to switch
    This would mean i would have the RBR50 Orbi router in the celler, where i do not need it. I want to have it in the flors where it is usefull.
