Suli3
Sep 14, 2018Aspirant
Wired backhaul setup - device chain
Hi all,
Yesterday I got finally my Orbi system and installed it immediatly. Now I'm trying to establish an wired backaul and I'm not clear about the exact setup.
My Setup: My house has an...
- Sep 14, 2018
Hi
Thanks for your reply.
I do not understand what you mean with Mft but this my setup:
Maybe I also explained it a bit wrong. It is not only a Cable modem it is also a router (inkl. Wlan).
(Cable 500Mb/50Mb)
UPC Connect Box CH7465LG-LC (Router ISP) --> TRN TEG-S16D (Swich unmanaged) --> Orbi System (RBR50 Orbi Router + 2 Satelites)
The router of the ISP provider and the switch are in the cellar.
QUESTIOn 1 again: Do i need to connect the RBR50 to the yellow internet port or to one of the other ports?
According to https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
Especially the third option i see (switch --> Orbi System (router + satelites) exactly how I did it or do I read this wrong?
Your advice Cable Modem -> Orbi system (1 router) -> Switch -><- Satellites and All other Network devices connected to switch
This would mean i would have the RBR50 Orbi router in the celler, where i do not need it. I want to have it in the flors where it is usefull.
Sep 14, 2018Guru - Experienced User
What is the Mfr and model# of the ethernet switch if one is in the configuration. Non managed switch is preferred. Orbi doesn't like Managed switches. If you have a managed switch try to disable IGMP protocols on the swtich.
Review this for configuration of ethernet connected satellites:
QUESTION 1: do need to plugin now the rooter to a noral port or still to the yellow internet port on the router? Depends if your modem or other router is in used. Yellow is normal.
QUESTION 2: does it matter which port on the satelites i use? No
QUESTION 3: do i need to set the router to AP mode or does this not matter? If you use a router upstream from the Orbi then use AP mode. If you use the Orbi after the ISP modem, then run it in router mode which would be preferred.
QUESTION 4: do the other devices on the switch (TVs, Playstation) distrub this setup. Should not, no.
Loking to the setup this would mean: Cable Modem -> Switch -> Orbi system (1 router + satelites). NO.
QUESTIOn 4: is the network setup ok or do i need: Orbi router --> Satelite 1 --> Satelite 2
Suli3
Hi
(Cable 500Mb/50Mb)
- FURRYe38Sep 14, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.The configuration I mentioned is preferred, however if your using a router already, then use the Orbi in AP mode. Yes you can use the Orbi in AP mode behind the switch in your configuration.
You can conenct the Orbi router using the Yellow LAN port to the swithc port. You can use the other LAN ports on the Orbi as well, however be aware you may see the top led on the Orbi turn on PINK. It's ok, just letting you know the LED behavior depends on use of the Yellow WAN port.
Mfr = Manufacturer - Suli3Sep 14, 2018Aspirant
Thanks this helped and works.
After a lot of tryouts I did as you adviced.
Solution for me: Cable Modem/Router --> Orbi Router --> Switch (unmanaged) --> All other deviced + 2 Satelites
Only in this confirmation i get the two satelites listed in the configuration as backhaul wired.
All other solutions did NOT work for me:
Cable Modem/Router --> Switch --> All other devices (Router + Satelites)
Cable Modem/Router --> Switch --> All other devices (Router AP mode + Satelites)
Unfortutently I cannot activate bridge mode on the Cable Modem/Router. An option to configure DMZ for the Orbi router was on my Calbe Modem/Router also not.
I forgot to mention how i connected:
From the LAN Port of the Cable Modem/Router --> to the yellow WAN Port of the ORBI Router --> from the first LAN Port of the ORBI Router to one free LAN Port of the Switch --> the two other satelites and a lot of other devices are then connected to the LAN ports of the switch (16 ports in total)
- Caroline285Sep 25, 2018Initiate
From the LAN Port of the Cable Modem/Router --> to the yellow bkexperience WAN Port of the ORBI Router --> from the first LAN Port of the ORBI Router to one free LAN Port of the Switch --> the two other satelites and a lot of krogerfeedback other devices are then connected to the LAN ports of the switch (16 ports in total)
Thanks, that really helped.
Your cable modem doesn't have a DMZ?
Glad you got it working. :smileywink:
