Afon
Jun 20, 2018Aspirant
Wired Backhual Installation Problem
Hi Community,
Started my installation today and hit a problem. I should first highlight that I've got a fairly long and old property that is actually split in two. In the past I've used a combi...
Afon
Nothing else in the mix. Replaced my BTHomeHub with the Orbi Router is all.
With regards to daisy chaining: a) where is the option to enable/disable, can't find it while scanning around, b) I originally thought I wanted the daisy chaining as my propery is long, with the router starting at one end.
Afon
Thought I was on the latest firmware, but reading your thread I'll have a go on .16. Nothing to lose as it doesn't work currently.
