Afon
Jun 20, 2018Aspirant
Wired Backhual Installation Problem
Hi Community,
Started my installation today and hit a problem. I should first highlight that I've got a fairly long and old property that is actually split in two. In the past I've used a combi...
Jun 20, 2018Guru - Experienced User
Whats the distances between each stalllite?
Maybe using wireless daisy chain would work...
- AfonJun 20, 2018Aspirant
Unfortnately I tried that intially to no avail. I shifted them as close as I could to windows in the respective buildings, but it is still about 30m with no direct line of site. The 2nd building is also a modern conversion with foil sheet insulation, so it is a bit like a faraday cage, especially the end towards the main house.
There is a chance another satellite in an outbuilding could create a hop, but I'd be at 5 devices at that point and given the cost I'd revert back to my current solution. Especially as I was hoping the new solution would resolve issues with iOS roaming, but I still seem to be getting some problems.
