Nachum
Feb 08, 2019Aspirant
Wired ethernet backhaul connection does not show status on orbilogin site
Hi I Use the Orbi RBK23-100PES (1 router + 2 satelites) I connect the satelites using wired connection (ethernet backhaul connection) I first sync the system not using the wired connection, ...
ekhalil
Feb 08, 2019Master
- Since your're using wired backhaul, please make sure Daisy Chain is disabled.
- What wired devices do you have connected to Orbi?
- Was the IP range 10.0.0.x selected by you or was it set by Orbi at initial setup?
- MoooseFeb 09, 2019Luminary
In trying to diagnose Ethernet backhaul issues in the last few weeks I have noticed lots of glitches in the web interface, such as wireless devices shown as wired and lagging connection status updates for the satellite. After it appears you have a good connection, try logging out from the web interface and restarting your browser.
