Nachum
Feb 08, 2019Aspirant
Wired ethernet backhaul connection does not show status on orbilogin site
Hi I Use the Orbi RBK23-100PES (1 router + 2 satelites) I connect the satelites using wired connection (ethernet backhaul connection) I first sync the system not using the wired connection, ...
ekhalil
Feb 08, 2019Master
- Since your're using wired backhaul, please make sure Daisy Chain is disabled.
- What wired devices do you have connected to Orbi?
- Was the IP range 10.0.0.x selected by you or was it set by Orbi at initial setup?
Nachum
Feb 09, 2019Aspirant
Hi
Thx
I disable the Daisy Chain, but still i do not see the devices as connected
I double check that this setting is turned off after the system has been reset (this change required system reset)
My Home is wired using Netger GS 608 1Giga switches (4 speard is misc places at home). I have several devices connected wired at home (PC's, TV's Streamers, printer and more)
The IP range was set automaticly to 10.0.0.x when i start the setup process
- Chuck_MFeb 09, 2019Mentor
I believe you are in a double NAT condition with a router somewhere behind the Orbi.
Are you able to describe precisely by make/model what is upstream of the Orbi (e.g. cable modem, switch, etc) and what is above that?
Solution is there to get this working properly, but you will probably have options to decide
- NachumFeb 09, 2019Aspirant
Hi
Attached my home network diagram- Chuck_MFeb 09, 2019Mentor
Great diagram (except for the watermarks! LOL).
Ok, the TP 600... I think that is actually a router and not a cable modem. Does it look like this?
https://www.tp-link.com/au/products/details/cat-15_Archer-VR600.html
It would HAVE to have routing functions since you have computers attached to the netgear GS 608... where would they get their I addresses from? That would have to be a router with DHCP functionality.
I would put the Orbi between the cable modem and the Netgear switch in router mode, and -- if necessary -- bridge the TP LINK
