nanohead
Oct 29, 2018Guide
Wireless and backhaul problems with firmware 210, technical observations and tests
I've been trying to diagnose these problems that many people are having and have been experimenting with a variety of things. Needless to say, there are clear Firmware bugs, without a doubt. The s...
AlexisG
Oct 30, 2018Aspirant
Since my Orbi system (wired backhaul) auto updated to 210, I’ve had the following new issues:
- Amazon Echo losing its connection
- Nintendo Switch losing its connection
- WeMo devices getting mistakenly coalesced into a single device to HomeKit, presumably via WeMo Bridge connected to the Orbi satellite.
- occasional dropped WiFi connection to the Apple TV
Basically, everything is now unreliable. Of course the irony is that this kind of nonsense is what I thought I was paying to avoid by buying an Orbi. Sigh
Oct 30, 2018Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001
Advanced Wireless Settings both 2.4GHz and 5GHz changed CTS/RTS Threshold to 2307.
https://community.netgear.com/t5/Orbi/Orbi-RBR40-RBS40-V2-1-4-16-mesh-network-drops-connection-to/m-p/1601598/highlight/true#M35230
Change the CTR/RTS threshold values for both 2.4 GHz and 5 GHz (2341 and 2345 respectively), changed preamble modes to long preamble, and Set 20/40Mhz Coexistence to 40Mhz only.
Try a Manual FW load:
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-released-as-of-10-3-18/m-p/1647303/highlight/true#M42416
