clivesay
Aug 10, 2018Follower
Wireless Backhaul or Ethernet
I need help getting wi fi over to my pool house. I have Orbi 24 with (3) satellites around my house that work great. I have now added a pool house about 250’ from the router. During construction I ran...
st_shaw
Aug 10, 2018Master
If the pool house is 250' away, you can also consider installing an independent wired access point at the pool house. Set it to use different channels than Orbi. You can probably do this more cheaply than buying a standalone Orbi satellite. You could use an old router in AP mode, if you still had one.
