OrbiNoob
Apr 27, 2019Follower
Wol help
I set up my orbi rbr20 as a wired access point and connected my PC via ethernet to the orbi. I can't get wol to work in this configuration. It was working when I had the orbi setup in router mode but for other reasons I needed to change it to access point mode. Is it possible to get wol working as I have it setup now?
One reason people have not responded to the question is ambiguity about what "Wol" stands for. "Wake on LAN"? An on-line computer game?
You would need to probably set the Orbi back to Router mode or configure WakeOnLan on your main host router while the Orbi is in AP mode.
