ffwill22's avatar
Nov 06, 2019
Won’t turn on
Device just stopped working. Three weeks after warranty expired. Please help
  • CrimpOn's avatar
    CrimpOn
    Is it correct to assume that you have (a) tested the electrical outlet with some other device that is know to work (light, radio, etc.), and (b) that you have swapped the power supply between the router and satellite?
    • ffwill22's avatar
      ffwill22
      Guide
      A yes I tried the router in another outlet that works. As for the satellite I turned it off. Thinking I would turn it on if I could get the router up and running
