Bing-Stroller
Sep 12, 2017Luminary
Wow!!! Orbi Firmware V2.0.0.72 Released
Just logged into my router and it gave me the option to upgrade the firmware.
Have now Upgraded to V2.0.0.72
Haven’t had too much time to explore but early indications are WOW !!!
cyberprashant
Mikey94025 wrote:My upgrade to 2.0.0.72 did not lose my old settings. My port forwarding, etc. all stayed put.
The new firmware lets you change the wireless power settings again, so you can set 2.4Ghz transmit power control to 100% / 75% / 50% / 25%.
i was coming from a modded downgrade to 1.11.0.20 so perhaps they saw it fit that mine needed a complete wipe. :D
SO far so good!
rajis
Sep 12, 2017Guide
Anyone testing out Live Parental Controls? I still get the "There was an error signing in, pleae make sure you're connected to the Internet and try again." that started showing up around 1.11.0.20
- JMU1998Sep 12, 2017Luminary
Are we allowed to finally use the Implicit Beamforming feature?
- peteytestingSep 12, 2017Hero
i have it enabled here and no issues , also have mu-mimo enabled
- JMU1998Sep 13, 2017Luminary
peteytesting thanks for the feedback. so we can assume that "Explicit" Beamforming is part of this Firmware and on by default correct? AND now we are OK to turn on "Implicit" Beamforming since bugs fixed so older devices/adapter cards can take advantage of this feature?
