Bing-Stroller
Sep 12, 2017Luminary
Wow!!! Orbi Firmware V2.0.0.72 Released
Just logged into my router and it gave me the option to upgrade the firmware.
Have now Upgraded to V2.0.0.72
Haven’t had too much time to explore but early indications are WOW !!!
Tigerman4LSU
Sep 15, 2017Star
Any way to force the Daisy Chain? My router in the media room connects to the Router, not to the Satellite that is closer and on the same floor.
Ely
Sep 15, 2017Luminary
Tigerman4LSU wrote:Any way to force the Daisy Chain? My router in the media room connects to the Router, not to the Satellite that is closer and on the same floor.
Your router? are you using the Orbi in AP Mode? if so the router is not supposed to connect to your Orbi but the other way around, Do you mean a Wi-Fi extender or repeater? in that case the Daisy Chain feature is I supposed only supported wile using the Orbi main unit and any additional satellites you connect to it.
- Tigerman4LSUSep 15, 2017Star
Too tired. I want this topology. Satelitte to Satelitte to Orbi Router.
- ElySep 15, 2017Luminary
Tigerman4LSU wrote:Too tired. I want this topology. Satelitte to Satelitte to Orbi Router.
Ok, not sure if this will work but you can try to force it to connect that way by basically turning off the Orbi's main unit (Router) then I guess both satellites might attempt to connect to each other instead? after a minute or two try turning on the main unit back on.
I believe it normally should do that though, so not sure what is causing your issue.
