Bing-Stroller
Sep 12, 2017Luminary
Wow!!! Orbi Firmware V2.0.0.72 Released
Just logged into my router and it gave me the option to upgrade the firmware.
Have now Upgraded to V2.0.0.72
Haven’t had too much time to explore but early indications are WOW !!!
aaz
Sep 21, 2017Virtuoso
Honestly, I am not seeing this band steering issue that is being spoken of.
I have 23 devices connected + 2 satellites. Everything appears to be connected to the proper band. The devices close by that can take advantage of 5 Ghz are using it and the ones further away I see are connected on 2.4Ghz.
I am not experiencing any dropouts, or streaming issues. I have 7 NAT rules to allow various connections into my network. I have the RBK50 purchased in Costo, and my cable modem 150Mb/16Mb up is running as a bridge directly to the Orbi on firmware 2.0 now.
I did have to turn off my UPnP which was the only issue I experienced with the Orbi, but otherwise the connections and the router have been rock solid stable. I'd have to guess that people that have customised settings probably triggered something in the software causing their own issues.
DasND
Sep 21, 2017Initiate
It amazes me how Netgear releases new firmware that is either retracted or is buggy. I don't know how new versions of firmware are quality tested but it's getting ridiculous. I spend so much time with each firmware upgrade dealing with magenta light that recurs.
- spinkickSep 21, 2017Apprentice
At this point, i think its environment. Wireless is complex and no two homes are the same. Imagine developing software to try and account for every single situation. its pretty mind blowing.
- superben79Sep 21, 2017Apprentice
When I checked via the UI, the v2 fw is still not yet available for the router and the satellite. I know I can manually download the fw from the dropbox but I am curious why i don’t receive the fw automatically.
- aazSep 21, 2017Virtuoso
superben79 wrote:When I checked via the UI, the v2 fw is still not yet available for the router and the satellite. I know I can manually download the fw from the dropbox but I am curious why i don’t receive the fw automatically.
I'm pretty sure you can't receive it automatically yet because they have not released it yet. They may be working on one last issue and the version that will be release is not the same as the one you can download now. At least I am hoping that's the case and not a case of some so called leader in the company that cannot make up his mind on whether to release this version or not.
