Bing-Stroller
Sep 12, 2017Luminary
Wow!!! Orbi Firmware V2.0.0.72 Released
Just logged into my router and it gave me the option to upgrade the firmware.
Have now Upgraded to V2.0.0.72
Haven’t had too much time to explore but early indications are WOW !!!
njweb
Sep 22, 2017Luminary
Does anyone know what changed in V2.0.0.74 vs V2.0.0.72?
Hydro130
I'm in the midst of the update now - I manually uodated the firmware (that went fine), and did a full factory reset and NVRAM-clear so far...
I'm not too deep into rebuilding my settings yet, but I did notice that the 3 options for Implicit Beamforming, MU-MIMO, and Fast Transition are all UNchecked by default - IIRC, those were all checked by default in .72
I'm planning to leave all three unchecked myself, but we'll see how it goes!
- aazSep 22, 2017Virtuoso
Hydro130 wrote:I'm in the midst of the update now - I manually uodated the firmware (that went fine), and did a full factory reset and NVRAM-clear so far...
That has got to be a mistake in their clearing routine. I've found those options very stable on .72, and if they are not on .74 I'll revert back to .72 until the next release.
- AmitRSep 22, 2017NETGEAR Employee Retired
So, as you discovered, we posted the new version on the support -> download site for you to apply to your systems. the auto-firmware push will happen soon, but we're giving you a window to manually apply the firmware upgrade before it gets pushed.
The only difference between .72 and .74 are a some bug fixes.
Orbi Product Team
- Hydro130Sep 22, 2017Luminary
AmitR wrote:So, as you discovered, we posted the new version on the support -> download site for you to apply to your systems. the auto-firmware push will happen soon, but we're giving you a window to manually apply the firmware upgrade before it gets pushed.
Orbi Product Team
Amit, can you please comment on the stability of the "Implicit BF" and "MU-MIMO" options in v.74?
In past firmware releases, DarrenM warned peope away from enabling those, saying they would be fixed/improved in a later firmware realease... Are those two options now fully ready-to-rock in v.74?
Thanks!
- DarrellRiffeSep 22, 2017Apprentice
The options are still there in .74. They're just not checked by default.
Yes, but I meant that it's likely an oversight on their part that they are not checked when you do the nvram reset. Or they would have unchecked them for me when I upgraded from .72 if they were deemed to be not ready.
I've been running with them all checked ever since 12 and the Orbi has been rock solid, all my devices connect, streaming is solid and speed is as fast as my internet allows and as fast as wireless allows for the NAS.
I would hate to see people thinking that they are unstable for no reason.
- hyeungSep 22, 2017AspirantHi,
When doing a firmware upgrade...you mentioned doing a NVRAM-clear?
Most times I have done a factor reset at most and don't recall anything mentioned in the instructions on a NVRAM-clear? Can you advise on this one? Or is the NVRAM-clear already done as part of a factory reset?
Thanks
HY- cinekSep 23, 2017Apprentice
just updated to 2.0.0.74 hopefully it'll be better than 2.0.0.72
