Bing-Stroller
Sep 12, 2017Luminary
Wow!!! Orbi Firmware V2.0.0.72 Released
Just logged into my router and it gave me the option to upgrade the firmware.
Have now Upgraded to V2.0.0.72
Haven’t had too much time to explore but early indications are WOW !!!
Kyne
Sep 23, 2017Apprentice
So, in this version - I see you can select implicit beamforming. Does that imply that - regardless of your choice here - explicit beamforming is always on?
thx!
- peteytestingSep 23, 2017Hero
i believe so
- rhester72Sep 23, 2017Virtuoso
Kyne wrote:So, in this version - I see you can select implicit beamforming. Does that imply that - regardless of your choice here - explicit beamforming is always on?
Yes, it's a mandated part of the standard and cannot be disabled.
Rodney
- KyneSep 23, 2017Apprentice
Thanks!
- cyberprashantSep 23, 2017Luminary
in order to get a ring doorbell far from the satellite to connect reliably, on 2.0.0.72 i had to again disable beamforming and MU-MIMO - now it seems to be working reliably!
