Bing-Stroller
Sep 12, 2017Luminary
Wow!!! Orbi Firmware V2.0.0.72 Released
Just logged into my router and it gave me the option to upgrade the firmware.
Have now Upgraded to V2.0.0.72
Haven’t had too much time to explore but early indications are WOW !!!
peteytesting
Sep 29, 2017Hero
although i wouldnt say mu-mimo is just smoke and mirors its certainly not a game changer for the average user no matter who much they try and convince us it is , mu-mimo along with link aggregation lof lan ports give little benefit to the average user case , implicit beamforming imho is an attempt to make older devices ( non ac ) work better than what they are designed to do and it never really achieves the same level as explicit anyway and in doing so can and does cause connectivity issues although i have to say i have it on here with my wemo light switch gear and it works fine and has no detrimental effect here being on
sure there is a very specific and very narrow band of users that would and will benefit from link aggregation and mu-mimo , but they are the 0.1% while the rest of us have no intrest in it or would ever actually use it
njweb
Sep 30, 2017Luminary
I have all 3 options below enabled on 2.0.0.72 and no issues with disconnects. Connectivity and stability are solid.
I do have daisy chaining disabled.
| Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices |
| Enable MU-MIMO |
| Enable Fast Roaming |
