Tr4nc3
Oct 16, 2017Initiate
WPA2 - KRACK / Vulnerability
Hi Netgear, I think this is really important and should be monitored closely and all the wifi users should ask the vendors to monitor an patch this. Looks like that WPA2 is about to be cracked and ...
- Oct 16, 2017
NETGEAR is aware of the recently publicized security exploit KRACK, which takes advantage of security vulnerabilities in WPA2 (WiFi Protected Access II). NETGEAR has published fixes for multiple products and is working on fixes for others. Please follow the security advisory for updates.
NETGEAR appreciates having security concerns brought to our attention and are constantly monitoring our products to get in front of the latest threats. Being pro-active rather than re-active to emerging security issues is a fundamental belief at NETGEAR.
To protect users, NETGEAR does not publicly announce security vulnerabilities until fixes are publicly available, nor are the exact details of such vulnerabilities released. Once fixes are available, NETGEAR will announce the vulnerabilities from NETGEAR Product Security web page.
wchp
Nov 05, 2017Luminary
Downloaded both files
unzipped both and read the release notes.
backed up 2.0.0.74 settings
manually installed 2.0.0.76 beta on both RBS50 units
once they rebooted and came back up on the new firmware
manually installed 2.0.0.76 beta on the RBR50
checked all settings and nothing changed...
BUT, normally when you install a beta firmware you are supposed to hard reset (paperclip) the router and satellites and then manually configure them from scratch. This is to implement the new code.
You are NOT supposed to restore from the backup you made on the previous version of firmware either. This is to preclude any settings being brought forward that may conflict or improperly interact with the new firmware.
It made no mention of doing this on the beta firmware page or in the readme files... so I didn't do it and don't really know if the "hotfix" is actually implemented and running on the RBK53 system. All devices report they are running the new firmware, but are they really without a hard reset?
I am going to defer to Netgear admins to provide clarification on this topic.
SkywalkerPD
Nov 05, 2017Apprentice
Hi,
Trying to update my setup, starting with the sattelite, I do a manual update, select the proper firmware, it uploads and that's it, nothing happens.
Any suggestions?
