jimbojames79
Apr 18, 2019Apprentice
WPS PIN
Hi,
Where can I find the WPS PIN for my router?
Thanks
Thanks
What model router do you have?
jimbojames79 wrote:
Hi,
Thanks- jimbojames79ApprenticeRBR40
Under Advanced Tab/Advanced Settings/Wireless Settings
jimbojames79 wrote:
Where can I find the WPS PIN for my router?Orbi does not appear to support WPS PIN method of connection:
https://www.computerworld.com/article/3193163/how-seven-mesh-routers-deal-with-wps.html
also see: https://kb.netgear.com/31239/Does-Orbi-support-Wi-Fi-Protected-Setup-WPS
- SW_Prodigy
jimbojames79 Wrote:
Hi,
ThanksTry this:
Replace 192.168.1.1 with your router IP address:
http://192.168.1.1/hidden_info.htm
You should see the "PIN Code" along with the rest of the secrets. Save a copy of that for future reference.
SW_ wrote:
jimbojames79 Wrote:
Hi,
ThanksTry this:
Neat.
