BedStuyBrenda
Sep 30, 2018Aspirant
Wrong password
I appreciate your help though this topic is old for most of you, I still need advise. I reset my router and modem but now my pass word is “incorrect” I’m connected to the internet, but I can’t log on ...
- Sep 30, 2018Thanks for the advice, I’ll give it a try.
Sep 30, 2018Guru - Experienced User
You'll need to factory reset the Orbi router and use a wire or wiress connected PC and browser and navigate to 192.168.1.1 and walk thru the setup wizard. This time write down all information for safe keeping later on.
- BedStuyBrendaSep 30, 2018AspirantThanks for the advice, I’ll give it a try.
- FURRYe38Sep 30, 2018Guru - Experienced User
Good Luck,
