Mitewot
Aug 24, 2020Aspirant
Xbox killing network
Have seen some previous posts but no real solution. Frequently when I go to connect to Xbox live it will knock my Orbi network offline. Still getting internet to the modem, but nothing beyond that. I have assigned static IP and put box in DMZ, but still not working. Any help would be appreciated.
- MstrbigMaster
Mitewot wrote:
Have seen some previous posts but no real solution. Frequently when I go to connect to Xbox live it will knock my Orbi network offline. Still getting internet to the modem, but nothing beyond that. I have assigned static IP and put box in DMZ, but still not working. Any help would be appreciated.Which model Xbox are you referring to. My Xbox 360 and Xbox One are not having any issues, I did not set up any ports, no DMZ, just forgot the WIFI networks and reconnected. Can get Xbox Live on both Xboxes. It probably has somethng to do with the static IP and DMZ. Try removing those settings, reboot the Orbi system, search for WIFI or connect cable, (which could also be the problem), on Xboxes and rejoin the WIFI network
- MitewotAspirantIt’s the XboxOne. The static IP and DMZ are my attempts to solve the problem based on some previous reads. The Xbox is direct connected to the router. Have experienced same issue wireless as well.
- MstrbigMaster
Mitewot wrote:
It’s the XboxOne. The static IP and DMZ are my attempts to solve the problem based on some previous reads. The Xbox is direct connected to the router. Have experienced same issue wireless as well.One, try to reconnect either wired or wireless. I'm not sure why it's doing what it's doing.Any switches in between the Xbox and satellite or router?
What FW version are you using on the orbi system?
What is the mfr and model# of the ISP Modem or ONT connected to the RBR?
DMZ is not needed or recommended for use with game consoles.
You only need to either use Dynamic IP addresses or set a reserved IP address ON the RBR for the xbox.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).One User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
