lannyreese's avatar
lannyreese
Xfinity modem with wifi routers
I need two different Wi-Fi routers in my home: one to run my Ring security system without interfering with my computer Wi-Fi network. I'm using the built in router in my Xfinity Modem for connecting to the Ring products. I'm using the Orbi router to connect to my computer products. Recently, I bought an Amazon Fire Cube to enhance smart features on a dumb TV in the bedroom. It found the Xfinify Router as there is an Wi-Fi extender right next to the TV. Alexa is fussing and sending out error messages because occassionaly the Wi-Fi loses the Up load channel and Alexa is unable to correspond with its server. Comcast says that I am not allowed to use both routers at the same time as they have to time-share and can lose the proper signals from Comcast. Because of my security setup and computer setup, I don't want to have to go around and change all of the settings on the security end of the package. Any suggestions as how I can continue to use both Wi-Fi networks at the same time?
  • FURRYe38's avatar
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
