Bolson32
Jul 11, 2018Aspirant
Yet Another VLAN Tagging Post
I have CenturyLink fiber directly into my house and I see that VLAN Tagging on the WAN port supposedly used to be a feature? However, it appears to not be available on the current firmware. Any chanc...
st_shaw
Sep 18, 2018Master
Just set your C2100T in transparent bridge mode and use PTM-Tagged and VLAN ID 201 on the C2100T Broadband Settings page. Then you can connect Orbi and it will pull a WAN IP throught the modem.
I have the C2100T and that is what I do. There is no need to have VLAN tagging support on the router at all. At least that's how it works with my CenturyLink service in a non-pppoe area.
- Bolson32Sep 19, 2018Aspirant
I've tried that and I lose internet connectivity. There's another post on here with someone who lives in a Centurylink PPPOE area that has the same issue. Doesn't seem to work as intended, to be fair I didn't give it an incredible amount of time.
Currently using it in AP mode, but I feel like I'm losing some of the traffic features, etc.
- st_shawSep 19, 2018Master
I'm in an IPOE area so I don't know if that makes a difference. I will say, however, that it was quite difficult to get transparent bridge mode to stick on the C2100T. I've seen others report the same issue. I had to try 3-4 times before it stuck. It's also easy to get the settings wrong. I had it connect in Auto mode, noted the settings, then changed to transparent bridge mode, and made sure the settings were still correct.
So, it would be worth trying again if you want to use Orbi in router mode. However, I use Orbi in AP mode and I'm quite happy with that.
I think, but am not sure since I don't have PPPOE, that it should work if you set the modem to bridged mode with VLAN tagging, (not PPOE mode) then setup Orbi to use PPPOE (but not VLAN tagging.)
You can see some screen shots here:
http://www.dslreports.com/forum/r31392463-Bridge-mode-for-C2100T-modem-VDSL2-IPoE
