esiebert7625
Oct 04, 2018Star
Your experience with Firmware 2.2.1.210 released as of 10/3/18
The other long thread on the new firmware is useless and has become a tech support thread. Please only post your experience after upgrading to the new firmware, good or bad. I'd like to see everyone'...
Oct 04, 2018Guru - Experienced User
Users should keep posting in this thread, regarless of good or bad experiences:
Helps to keep posts about this version of FW central and so users and NG support and see whats going on. Instead of having posts all over the the place.
- DonnnnOct 04, 2018Aspirant
This update was applied automatically and a taken my one satellite offline. It's in "config sync" mode. I definently did not choose to apply this update.
Even a hardware reset has not solved the issue. Tonight I will reinstall the older firmware.
- OzzzieMikeOct 05, 2018ApprenticeThis latest firmware bricked my RBR50 router. After around 3 hours and 3 phone calls with NETGEAR yesterday, they are sending me a replacement router.
Symptoms after the firmware update (accomplished via iOS Orbi app)...below is a condensed listing of what happened.
— App said Update was complete, and was reconnecting to WiFi.
— Tried several times (tapping Retry) in the app, but still couldn’t connect to WiFi.
— Checked available WiFi networks, and mine wasn’t listed.
— While on phone with NETGEAR, tried both a 30 second and 60 second reset on the router...WiFi signal never appeared.
— While on phone with NETGEAR, I connected an Ethernet cable between a PC and the router. Wasn’t able to access orbilogin.com.
— At this point, support said they’d done all they could, and the router will have to be replaced.
So there’s nothing more I can do until the replacement router arrives. (Am also hoping the satellite wasn’t bricked as well....won’t know until I try setting up the router).- FURRYe38Oct 05, 2018Guru - Experienced User
You should always have a PC connected to the Orbi wired for doing any FW updates. https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-released-as-of-10-3-18/m-p/1647303/highlight/true#M42416
Have you tried recovering the Router?
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
Some say using the Windows TFTP program works over the one mentioned in the link. Try both...
- AnonymousOct 05, 2018
I beleive the first thread you mention was more intended as an announcement. Whereas the one started here is actually looking for experiences.
