esiebert7625
Oct 04, 2018Star
Your experience with Firmware 2.2.1.210 released as of 10/3/18
The other long thread on the new firmware is useless and has become a tech support thread. Please only post your experience after upgrading to the new firmware, good or bad. I'd like to see everyone'...
ratb3rt
Oct 06, 2018Tutor
Update went smoothly. However my two Carrier Infinity Touch thermostats lost connection and I could not get them to connect manually no matter what I tried. Every other device had no problem. I rolled back to 2.1.4.16 firmware, and they connected within minutes. They identify themselves as "Microchip Technology Inc.". Please fix this incompatability. I have a router and two satellites. When I check for networks to connect to it shows all three devices as separate networks. Three networks with the same SSID. I don't see this on any other clients.
The roll back procedure needs some work. When trying it with the cable modem connected the firmware kept going back to the latest version even after manually updating to the old firmware. I don't know if it was really, but the router kept insisting that is was on the latest 2.2.1.210 firmware. Once I disconnected the cable modem I was able to update everything back to 2.1.4.16.
- OzzzieMikeOct 06, 2018Apprentice
This is not specific to this latest update, but I've noticed a lingering problem with my Orbi RBK50 system still exists:
Often (at least once a day on at least one device) I'm not getting a response when I surf to a website or social media site. I've found that turning WiFi off/on on the device cures the problem.
As this happens on my Macbook Pro, iPhone, iPad, and a Windows Surface Book 2, it can't be operating system specific....and the only common link I can think of is the WiFi network.
- steve8411Oct 06, 2018Apprentice
This is the problem most of us have had ....
This build seems to fix it.
- loomis1975Oct 06, 2018Luminary
After Manually Updating RBS40V to 2.2.1.62 and RBS50Y to 2.2.1.204, I then let Online Update take care of RBS50 and RBR50 to 2.2.1.210. This is through a PC Chrome browser connected wirelessly to the RBS50. Only the RBS40V daisy chains and that is through the outside Orbi, the RBS50Y.
The internet starting working almost immediately and the correct diagnostics (satellites actually showing up under the satelittes header, backhaul showing poor or config synch etc) worked themselves out after about a half hour of leaving it alone.
So alls well that ends well here, so far.
- ratb3rtOct 15, 2018Tutor
Just want to update my post from 10/6. I had rolled back the firmware so my two Carrier Infinty Touch thermostats would connect since they would not with the new firmware. Well on 10/14 I got an email from the Carrier Server that my thermostats had not reported in for a while. I checked the router and found it had autoupdated to the new firmware. I disconncected the cable modem and tried to roll back the firmware again, but as soon as I connected the modem the router autoupdated the firmware again. TELL IT TO STOP AUTO UPDATING! I would but there is no way to turn it off. Horrible way to configure it. You HAVE to be able to roll back firmware when it breaks your network! I tried a factory reset but that did not help. I tried changing channels on the 2.4G network. I tried changing CTS/RTS threshold, changing MTU size, turning off 20/40 MHz coexistence. I tried turning off Daisy Chaining. All that did was give me a poor connection on the satellite furthest away. I do not have beam forming, MU-MIMO, or fast roaming enabled. I can get the thermostats to connect to the wifi by using the guest with no security, but they cannot connect to the Carrier server because it is not a secure connection. I need them to connect to the server for remote access and weather information, etc. I have never had anything like this happen in all the years I have had wireless. I have a $300 network router and I will have to add an access point to get my two thermostats back. All because I cannot roll back the firmware. What a joke.
- vice86Oct 15, 2018Aspirant
Yep, super annoying that they just decided on their own to upgrade our firmware without our knowledge. It's screwed my devices up...and you can't even contact them thru their site without paying for support..der. All you can do is leave them a tweet but of course they wont reply to that either since it would be a free reply.
- FURRYe38Oct 16, 2018Guru - Experienced User
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. Hoping NG support can have a look at this. So try this out as well.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001Try this:
- ekhalilOct 15, 2018Master
ratb3rt Carrier Infinity Touch Thermostats seem to only support 802.11b and only WPA2 security. Please make sure that you have 20/40 MHz coexistence turned ON and that you have security option WPA2-PSK (not WPA-PSK [TKIP] + WPA2-PSK [AES]).
- AustinNativeDec 06, 2018Initiate
I have a similar problem. Any solutions yet?
- FURRYe38Dec 07, 2018Guru - Experienced User
Try a factory reset on the system. if this fails,
Try a Manual FW load:
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-released-as-of-10-3-18/m-p/1647303/highlight/true#M42416Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
What WPA security modes are you using? Try using WPA2 and AES only.What is the Mfr and model# of the ISP modem the NG router is connected too?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.Try disabling the following and see:
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
- njwebDec 27, 2018Luminary
Update - I have been on this 2.2.1.210 firmware since October and my wifi connection has been rock solid. I work remotely often and use Citrix Workspace to connect to my virtual work desktop and have not suffered any disconnects in a long time (since getting Orbi firmware 2.2.1.210 in fact).
With one of the PRIOR recent firmwares (do not recall which one) I was having sporadic disconnect issues, but those issues stopped competely after getting 2.2.1.210.
