esiebert7625
Oct 04, 2018Star
Your experience with Firmware 2.2.1.210 released as of 10/3/18
The other long thread on the new firmware is useless and has become a tech support thread. Please only post your experience after upgrading to the new firmware, good or bad. I'd like to see everyone'...
MikeTheActuary
Nov 10, 2018Tutor
Has anyone else had issues with the nvram commands not being as "sticky" as they should be?
Since I made my last post, I've had to downgrade my RBR50 and RBS50 twice, even after setting and committing the nvram settings (including the newer orbi_auto_upg) to supposedly block auto-updates.
While I have not tested this fully (I'm trying to get some work done without the corporate VPN getting disconnected every couple of hours), the behavior is almost as if the Orbi triggers a flag for an auto-update once it learns that firmware updates are available, as it tends to do if you have gone to the firmware update page in the Advanced menu.
I'm hoping that re-resetting the nvram settings after an update is detected, and then simply not going back to that section in the Orbi settings will do it.
....and while typing this message, my Orbi just auto-updated back to .210.
I think I'm going to go check and see if I'm in some kind of warranty/return period, and figure out what I need to order from Ubiquiti. I've wasted too much time on this already, and as a telecommuter, I can't risk my corporate VPN or VOIP going down every couple of hours.
LycanChief
Nov 10, 2018Star
I am mad, and calling right now support and creating a complain... this is out of hand, from the bigining of october.. They dont look at their community and see this is a major issue....
I downgraded over a week ago, did the telnet commands to the nvram, everything was working perfectly until today, aparently they force the upgrade to .210....I am calling.... No way to disable autoupdate aparently
- LycanChiefNov 10, 2018Star
Great, they hang-up on me! Class Action Sude! Anyone!
- JeroenMNov 10, 2018Guide
Hmmmmm mine is also back to 210.
I also blocked auto update with telnet.
That's why my wifi was so bad today.
- ekhalilNov 10, 2018Master
In 2.2.1.210 Netgear has fixed issues related to wired backhaul and I guess that this might have affected the sensitivity of the system to wired devices.
I'm saying this because I had all different types of issues with this release when it first came out in October: Wifi drops, no internet, worst internet speed, ... etc. I simply could not work from home becaue of my bad wifi at that time.
When I dosconnected the wired devices connected to the Satellite all issues were solved at once. I found out then that my wired speakers -for some reason- caused all issues.
I have now the best wifi network I've ever had, a very stable network with excellent coverage.
Please troubleshoot you issues by looking at your configuration and try to locate where the problems are. Look specifically at your wired devices. try first to disconnect all wired devices and if you see improvement, try to connect them back one by one to find the culprits.
Sorry, but sound sad, that you must disconnect your equipment to get everything working that was working perfectly before .210
- FURRYe38Nov 10, 2018Guru - Experienced User
Try this:
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
- Flash008Nov 10, 2018LuminaryIs Netgear going to do ANYTHING to help, or just ignore and provide ridiculous “suggestions” of “try to disable daisy chain”....”try factory reset”....”change your radio channel”...etc, etc, etc...unplug your product you paid $1000 or more for and see is that helps (LOL)....???!
Or maybe....
REMOVE 210 FROM THE UPDATE SERVERS, LET US DOWNGRADE TO 204 AND PROVIDE SOME IDEA OF “WHEN A FIX WILL BE PROVIDED?!!!!!”
Even APPLE, which rarely admits to bad updates, removes updates when they hear its causing problem....E.G....Apple Watch OS 5.1....
This is truly sad of Netgear.
Very, very....sad.... - LycanChiefNov 10, 2018Star
100% agreed, I just downgraded again! And Modify the nvram again! Will see how it goes...I have a case open with support…. I just want to know if anyone that have issues had call and complain… apparently NG don’t care about their community or they don’t read anything…
We all have done this, too many times, again disable features that where working before is not a good way to fix it... Just pull out the firmware and stop auto update until NG fix the issue!
- vice86Nov 11, 2018Aspirant
Or easier, stop auto-updating our Orbi systems!!! I still don't understand why they started auto-updating us. Luckily all my LIfx bulbs are ok now on the latest firmware but stop with the auto-updates. I want to update on my terms.
- ekhalilNov 11, 2018Master
Yes, not that optimum for me, but at least I solved my issue and now have a great wifi. I have the speakers connected wirelessly to Orbi and working great since the wifi coverage is excellent.
I’m saying this to tell you that Orbi is working for some people, the Orbi firmware is not perfect yet for sure, and seems very sensitive to ccertain conncted devices. I hope that NG will fix this soon.
I meant that with some troubleshooting, everyone can locate where the problems are, get Orbi working and get the best out of it. This will also help NG fix the right things in the coming software releases.
- JeroenMNov 11, 2018Guide
After again disappointed kids because the rented online movie keeped stopping (on a smart tv with a LAN cable connected), called our cable internet provider to switch the modem back to router modus (i was on bridge modus, as i hoped the orbi system could handle all the router "things").
So now back on the (ziggo) modem & router and switched Orbi to AP modus.
FURRYe38 did all the things you suggested here (and also other tips on other topics).
My conclusion: The 210 firmware of Orbi can't handle big streams Lan or Wlan
- FURRYe38Nov 11, 2018Guru - Experienced User
You can down grade to v.16 and see if this might help:
Download version 2.1.1.16 for both the router and satellite.
https://community.netgear.com/t5/Orbi/Orbi-RBK50-firmware-V2-2-1-210-update-slows-WAN-speed-with-30-to/m-p/1651159/highlight/true#M43338You'll need to block the auto updater...
I did downgrade to 2.1.4.16 and telnetted to block auto update.
Fortunate the orbi's felt like updating and did??? (could it be because i logged in with the orbi app??)
I now downgraded to 2.1.1.16 and again blocked auto upgrade.
Wil post an update if i got news :-)
Ya, possible the app checks updates regardless of whats set on the Router itself.
Let us know...
- UnhappyOrbiUserNov 11, 2018Star
You didn't forget the "nvram commit" or something?
It'll be frustrating if blocking auto-updates doesn't work. Next step will be to figure out what traffic to block.
Yes i did the commit :-)
Don't be surprised if NG is working to disable any kind of update blocking. :smileyfrustrated:
They shouldn't be surprised either if I never buy one of their products again.
Not the first one and probably not the last.
should they be focussing on fixing the 210 ????? :robottongue:
- nanoheadNov 11, 2018Guide
Yep, too bad too, as I've had decent luck with their stuff over the years. Most of the consumer network providers have gotten better since the early days. But these messy firmware changes have become a horror for all of us that rely on their hardware to enable our networks. You don't see these kind of really bad problems with the companies that sell enterprise/commercial products as often, which is why I've used mostly that stuff for years. Figured I'd try some new consumer stuff this time around, and I now regret it. The consumer network companies are completely non communicative with their customer bases, which is somewhat undstandable as they are enormous, but these are true Severity 1 problems, and Netgear is really failing us all.
No kidding.. after years of getting by with cheap routers and messing around with OpenWRT, I finally bit the bullet and decided to spend the money for one of these supposedly better systems, especially as I needed something to extend the range. I tried the Orbi and another one (I forget which), and stuck with Orbi for some reason.
Like you, I regret the purchase, it isn't worth the money I shelled out for it.
- MikeTheActuaryNov 12, 2018Tutor
Regarding my report of auto-update-blocking not taking:
When I originally attempted to block the auto-update, it looks like I didn't change the orbi_auto_upg setting - the 4th one that was added after the common instructions were written.
Aggravating matters this weekend was that I think I went through three rounds of downgrade-then-immediately-auto-update. In one of the more memorable iterations, it auto-updated while I was working on the nvram settings.
My threat to shop for Ubiquity gear seems to have done the trick, as my Orbi became stable (on .146, without auto-updates) shortly thereafter.
