esiebert7625
Oct 04, 2018Star
Your experience with Firmware 2.2.1.210 released as of 10/3/18
The other long thread on the new firmware is useless and has become a tech support thread. Please only post your experience after upgrading to the new firmware, good or bad. I'd like to see everyone'...
Nov 10, 2018Guru - Experienced User
Try this:
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
JeroenM wrote:
Hmmmmm mine is also back to 210.
I also blocked auto update with telnet.
That's why my wifi was so bad today.
LycanChief
Nov 10, 2018Star
We all have done this, too many times, again disable features that where working before is not a good way to fix it... Just pull out the firmware and stop auto update until NG fix the issue!
