esiebert7625
Oct 04, 2018Star
Your experience with Firmware 2.2.1.210 released as of 10/3/18
The other long thread on the new firmware is useless and has become a tech support thread. Please only post your experience after upgrading to the new firmware, good or bad. I'd like to see everyone'...
Retired_Member
Dec 31, 2018Firmware 2.2.1.210 has not resolved the issue.
With previous firmware, I had reboots every 2 to 4 hours. With 2.2.1.210 firmware, the behaviour was the same. Multiple factory resets didn't have a measureable difference. Netgear support was useless (support case 40456255) and just closed the ticket without resolving the issue.
My setup:
- Huawei HG659 ADSL modem
- 192.168.0.1 LAN Address
- uPnP disabled, DHCP disabled
- DMZ set to 192.168.0.2
- RBR50
- 192.168.0.2 WAN Address, static IP
- DNS configured as Google 8.8.8.8 and 8.8.4.4
- 192.168.1.x LAN Address; DHCP enabled
- uPnP disabled
- Network
- Two Kindles, one iPhone, one Android phone, one LG Smart TV
- One weatherstation
- Four Desktop PCs (two Windows, two Linux)
I did once get 41 days of uptime before the behaviour returned without any changes to the network setup, devices on the network, or usage patterns. The RBR50 seems to be very sensitive to something on the network, but since the logs are stored in RAM and not to flash, it is impossible to determine what the cause is. I offered to open the device and collect serial logs from the kernel to get some more clues, but support wanted me to "focus on the LEDs" and "try a different power source". Since both the modem and router are connected to the same power source and the only time the modem has reset has been when I have reset it, implies that the issues is with the RBR50 itself.
Ideally, I would swap out the Huawei HG659 ADSL modem to see if that makes a difference, but that is forbidden by my internet provider.
I have given up on Netgear products at this point and will be returning the RBK50 setup as defective to the retailer this week.
-Eric
Dec 31, 2018Guru - Experienced User
Did you try AP mode with the Orbi? I would try this? Use the modem as your main host router and just disable Wifi on the modem. Set AP mode on the router...
Also Try a Manual FW load and reset and setup from scratch:
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-released-as-of-10-3-18/m-p/1647303/highlight/true#M42416
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using? Try WPA2 and AES only.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Disney Circle: https://community.netgear.com/t5/Orbi/WARNING-Firmware-2-2-1-210-is-junk/m-p/1667485/highlight/true#M45926
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. Advanced Tab/Advanced Settings/Wireless Settings.
My setup:
- RBR50
- uPnP disabled
- Network
-Eric
- Retired_MemberDec 31, 2018
Hi FURRYe38,
Thanks for the reply. I've answered your questions below. I think the only thing that is different from your suggestions is that the 20/40 MHz Coexistence is enabled. In my case, the wifi connectivity is fine as long as the router doesn't reboot, so most of these setting changes are moot. Since Netgear doesn't provide support after 90 days, this router is going back as defective/not-fit-for-purpose to the reseller. I don't buy networking gear to become a networking expert and constantly fiddling with settings and do factory resets every few weeks.
Yes, I tried this with previous firmware -- same behaviour.
I've already done a factory reset and the firmware updates are fine. I don't have any missing GUI options as other people have mentioned.
Distance is approximately 3 meters through a wood floor.
What does this have to do with the router rebooting? As long as the router is running, the wireless connection is flawless.
Closest neighbour is 800 meters away.
It is already set to WPA2-PSK [AES].
> and satellite(s).
Enable Daisy-Chain Topology is enabled. Implicit BEAMFORMING is diabled; MU-MIMO is disabled; Enable Fast Roaming is disabled.
Enable 20/40 MHz Coexistence is enabled which I think you are saying it should be disabled.
- FURRYe38Jan 01, 2019Guru - Experienced User
I don't think your systme is defective.
Was this tried with current FW?
You should try a full manual RELoad of FW and factory reset and setup from scratch. This helped others in the operation of there systems. Not with missing GUI items.
10 feet to TOO close to each other, the router alone can cover up to 30 feet to begin with. Your system was probably rebooting trying to get a clear channel and the router and satellite had too much signal over lap.
Your system was probably rebooting trying to get a clear channel and the router and satellite had too much signal over lap. Auto can cause reboots as if the signal degrades, Auto will stop the router and it will reboot to see if I can find a better channel. Channels listed should have been tried.
> and satellite(s).
You can try either method. If you don't have many neigbors near by, then you can disable this.
- georgenganJan 03, 2019Star
I'm in the UK. My configuration: RBR50 + RBS50 + RBS40 with. No change in placement for 13 months. RBR50 is in the basement. The RBS50 is two floors above the router and the RBS40 is one floor above the router. Before the auto update of 2.2.1.210 (therefore I am not sure about the exact date of the FW update), the RBS50 is daisy chained to RBS40, and RBS40 is connected to RBR50. All wirelessly connected.
(1) Around/right after the auto FW update, there were increasing occurances of droping wifi signal (iMac wifi signal icon shows disconnection for a sec or two and then re-connected). I'm ok with it becuase I rarely stream.
(2) About two weeks ago, connection speed slowed down by half (from 55+ Mbps to 25+MBps), we have many imacs/ipads at home, and most of the connections change from 5G to 2.4G. I performed the normal power-down/power-up and resync. Most of the iMac still connect at 2.4G with reduced download speed. I can live with that.
(3) I havn't checked the Router page for a while and I check it today. Two strange things happened: the satellites are no longer daisy chained but all connected to the router; the backhaul status show poor connection. The imacs are still connected at 5G for those attached to the RBS50, but those devices connected to the RBS40 shows 2.4G. Download speed is only 25+ for those at 2.4G.
(4) I poweroff/on all three orbis, all backhaul status are still "poor" after one hour and the two satellites are still connected to the router (it takes sometime for the orbi to "sink-in" the config as far as I understand). I finally found this thread and change the 2.4g channel to 11. Now, the backhaul status of the RBS50 is still poor (naturally because it's tow floors above the router) while the RBS40 is showing "good". HOWEVER, when I run broadband speed test on all computers and devices, the speed are now back to 55+ Mbps.
The strangest thing is about daisy chain, it makes no sense for the RBS50 connecting to the router because it is definitely further away from the router than to the RBS40!
Just FYI.
BTW,
(1) I don't have any network analytics tool to check for channel jam/traffic from other wifi routers in the neighbourhood.
(2) I also changed the 5G channel randomly to 48 from 40.
- FURRYe38Jan 03, 2019Guru - Experienced User
Do a full reboot of the ISP Modem, Orbi router and satellites.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
What WPA security modes are you using? Try WPA2 and AES only.Try disabling the following and see:
Disney Circle: https://community.netgear.com/t5/Orbi/WARNING-Firmware-2-2-1-210-is-junk/m-p/1667485/highlight/true#M45926If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. Advanced Tab/Advanced Settings/Wireless Settings
Just FYI.
- teddyp12Jan 30, 2019Initiate
Ever since the update initialized, my orbi router appears to be cycling every few seconds causing havoc on my security system and business computers using USB WIFI adapters. If have attached my event logs since the automatic update in hopes that someone can make a recommendation.
It was completely stable before the initialization.
[UPnP set event: del_nat_rule] from source 192.16x.x.x, Tuesday, January 29, 2019 17:52:21
[UPnP set event: add_nat_rule] from source 192.16x.x.x, Tuesday, January 29, 2019 17:52:16
[UPnP set event: del_nat_rule] from source 192.168.1.7, Tuesday, January 29, 2019 17:50:54
[UPnP set event: add_nat_rule] from source 192.16x.x.x, Tuesday, January 29, 2019 17:50:51
[UPnP set event: del_nat_rule] from source 192.16x.x.x, Tuesday, January 29, 2019 17:50:46
[UPnP set event: add_nat_rule] from source 192.16x.x.x, Tuesday, January 29, 2019 17:46:28
[UPnP set event: add_nat_rule] from source 192.16x.x.x, Tuesday, January 29, 2019 16:22:50
[UPnP set event: add_nat_rule] from source 192.16x.x.x, Tuesday, January 29, 2019 16:19:58
[Time synchronized with NTP server] Tuesday, January 29, 2019 16:19:53
[UPnP set event: add_nat_rule] from source 192.16x.x.x, Tuesday, January 29, 2019 16:19:42
[admin login] from source 192.16x.x.x, Tuesday, January 29, 2019 16:19:36
[UPnP set event: add_nat_rule] from source 192.16x.x.x, Tuesday, January 29, 2019 16:19:03
[Internet connected] IP address: xx.xx.xx.xxx, Tuesday, January 29, 2019 16:18:45
[Initialized, firmware version: V2.2.1.210] Tuesday, January 29, 2019 16:18:44 - JoeCymruJan 30, 2019Virtuoso
UPnP is more for a home system, and even then it is a potential security issue. Personally I would never use UPnP in a business atmosphere. Actually I always check at updates to make sure it is disabled.
Devices on your system are constantly trying to open / close firewall ports and / or are sending requests to reconfigure themselves for whatever reason. Maybe gaming? But in general, not good. If you need specific connections use port forwarding so you can be selective and a lot more secure. More of a hassle but for the sake of security it is worth it.
Thanks for the advice, It has corrected my issue. I removed the UPnP access and went back to wireless WPA2-PSK access.
I also disabled and enabled my firewall to give my security system access.
