toms808
Feb 17, 2016Aspirant
341U on win 10
Has anyone got the 341U to work on windows 10? Sprint support says it is not compatible with win 10 at this time.
toms808
Feb 21, 2016Aspirant
thanks, will try the suggestions
Nati_S
Jun 24, 2016Tutor
Were you able to get this resolved ?
I have a Surface book that recognizes the 341u in the devices manager. All firmware and drivers have been updated but I cant get any connectivity.
- DarrenMJun 27, 2016Sr. NETGEAR Moderator
Hello Nati_S
Have you checked the thread I linked to try what was discussed in that thread?
DarrenM
- Nati_SJun 27, 2016Tutor
Hi Darren,
Yes I did. It's strange, when I first connect the aircard, the aircard watcher states modem detected, then 2 seconds later it states " No device detected"
Also, yesterday I connected the aircard to a usb 2.0 extension and I was able for the first time to acces the modem link. I however only lasted about 2 minutes then disconnected and I can't access anymore even after various attempts of disconnecting, rebooting, uninstalling usb drivers, etc....
The firmware and drivers were all updated to the aircard through a windows 7 laptop. I am convinced it is an issue with it not functioning properly in a 3.0 usb port. Thoughts ?
Thanks,
http://screencast-o-matic.com/watch/cD1ufViOu1
