therawski
Aug 30, 2017Guide
4G LTE Modem LB1120 extremely slow speed on T-Mobile
I recently picked up a Netgear 4G LTE Modem model LB1120 to use with my T-Mobile unlimited plan and when I plug the sim card in (from the phone that I'm not going to use anymore) I get extremely slow...
LGTurk
Dec 13, 2017Tutor
I have exactly the same issue. Evidently T-mobile can tell when Data transactions are being requested by a ‘non-phone’ piece of hardware and will apply a speed limit of 0.5 mbps. NOTE: if you have the ‘One +’ plan enhancement, it will go faster until you hit 10gb of data consumption then it really slows down (can be way down to 0.1 mbps !)until next billing cycle. Does anyone know how to set up the Netgear LB1120 or LB2120 modem so it looks like a cell phone requesting data??
therawski
Dec 13, 2017Guide
I found that you can change the ttl to do this.
you can do this with open source router firmware but in my case I can only do it on my pcs because I have an incompatible router
on your pc open a command prompt with administrator rights
type:
netsh int ipv4 set glob defaultcurhoplimit=65 (or 66 if you have a router or switch connected to the modem between your pc)
This will make the modem see your computer as if it was an android or iphone but I would suggest you don't go download crazy
I have the One+ plan and still had to activate HD streaming even though it said I didn't, it just gives you a pass for a few thousand days or something, lol
